I read that we can only record one episode while we watch live tv.
Is it possible to sync two formuler to records more episode ?
second hands, how many records can we do if there is no live watching ?
Best regards,
Best regards,
I can't get mine to see each other on network so I doubt it. I hope i get told I'm wrong
All Infos in this post -> Beta firmware 1.4.63 / Mytvonline 2 software 7.8.1 (6 May)
Read also the "Important part" to understand how this work.
No.
Recording only one and watch other, if you not watch one but changed before to other channel and record other channel, you still use 2 lines.
I've contacted 2 of mine and they don't let you do this
Thanks all,
I understand the we have 2 lines, so if nobody using formuler, it will be possible to records 2 channel.
What do you mean by «but changed before to other channel » ?
If I preset 2 records, I understand that eventually if I open the box during record it will stop ?
Do you have the right step to do properly (link) ? I saw cupule of channel, but I don't want to do wrong way,
Finally, by the pas beta version do you know if the officiel version was in fonction soon ? Or I could take while usually ?
The feature "recording one and watch other channel" means exactly that, you can record one and watch other or record one and timeshift other but you don`t have (at least for now) the possibility to record two channels at once. This will be improved step by step in future.
Please understand this feature is more complicated then people think, because as dev. you must improve the recording part in live channels + PIP + DVBT-2 so everything match.
That's clear ! thank you.
How could we be in touch when those upgrade will be available ?
All new Infos, updates and change logs are announced in this Forum and in Update threads. Explore the Forum and you will see.
I have now connected 1 Z8 to other as Network Drive. The funny thing is , when i just had NAS connected and I restarted box Nas appears then went VPN started it disconnected. With other Z8 and NAS mounted /restart NAS reconnects and stays connected when VPN starts but Z8 disconnects. Spoook
y
NOOO just done same on other Z8 and both get kicked after restart.
(This is what is all about watching the pictures gets boring![]()
