two devices with similar issue, if you watch tv it shutdown mytvonline and goes to the home menu.. i saw the issue was solved in previous updates .. but now the issue is back.. any way to solve this?
Watching tv mol shutsdown after few minutes
- MYTVOnline1
- Zx 5G
nouaro -
July 30, 2020 at 10:13 PM -
Happens with fw and sw version? Connection with your provider, registered MAC /ID Stalker portal, XC Api with login portal or m3u playlist?
Did your provider changed again the panel?
the connection is by xc portal api, 20 other clients with the same formuler have no issue.
What do you mean with sw and fw?
software firmware
Ah yes that is up to date always
I guess on this two boxes was the backup from other box restored, right?
Please delete cache and data, restart the box and test again. If the issue appear again, please do factory reset.
Sam thanks after a factory reset both devices work fine again!
Great, thank you for the feedback.
