hello with my formuler z8 the Netflix app doesn’t log in yes but i cannot select anything remote control doesn’t react what could that be
formuler z8 Netflix
cekcey -
August 19, 2020 at 2:28 PM -
if you didn't get Netflix app from the market,, I'd delete it and do that and see if it makes any difference.
the Netflix app was already on should I uninstall it and then reinstall it from Google Play Store or install it from my market?
I would uninstall and try market first and then if no luck give play store a try. Nothing to lose.
Netflix in the market no longer works and I can no longer download it from play store. I downloaded the apk searching on google and I solved it.
how can i delete apps?
Home/ Settings/Apps/select app press OK then go down to uninstall
When I start playing a movie on Netflix app it says it’s Netflix service is unreachable and stops the video. Where can I get a better version of the app for my Formuler z8 and the market one doesn’t work
Where did u download it from??
