Not able to Filter on VOD / Series
  • If you are using Portal, the VOD filter operates on the server-side.
    The server must send the correct filtered dataset to your Formuler device when you enable the filter.
    In other words, it doesn't seem like a problem with MOL2. Something is broken on the server-side.
    If you have doubts, try using stbEmu and try the filter function to see if it works properly or not.
