  • I I posted about this a while back. I'm still having problems. Received a message that ITV hub no longer works on my device after it prompted me to upgrade. I deleted and every time I reinstall the APK file from any of the usual APK websites, the same thing happens it prompts me for an upgrade and tells me that the app is no longer compatible with this device, and to check with the developers. Is anybody else had any experience like this with the ITB hub, and has anybody troubleshooted it. This cannot be unique to me!
  • I think I remember your post a while back and may have commented. I've had my Z8 coming up to a year possibly and the ITV Hub was one of the first applications I installed as my other half uses it most days. I have never had a problem with it myself and it has always worked correctly. The only thing I remember is I had to switch my VPN off when setting up and run the app through split tunnel to get it to work due to their Geo-blocking policy and that's it. It has been absolutely fine ever since. I hope you manage to find a solution.
