Dear expert users,
I have a Z8 since a year and I just find out that my Ethernet connection is limited, now that I broke up my wifi antenna.
I have a theoretical internet connection speed of 400 Mb/s. When I connect with a Gbit ethernet cable directly to my Z8, the maximum speed I get is 33 Mb/s. This is similar to what I actually get from my broken wifi antenna.
I have tested using my laptop. When I connect exactly the same ethernet cable to my laptop, I get an internet speed of 340 Mb/s.
My ethernet connection on the Z8 is done using DHCP.
Would you please support me to understand why I have limited ethernet speed with my Z8? I thought the Z8 is compatible Gbit ethernet port, is it correct?
Best regards,
Makcoul
