hi there i put my z8 on tonight and in settings i changed screen to 16,9 auto now i am stuck on black screen any help please
No Signal
mine will not turn on .can not see nothing
my hdmi 2 keeps flashing
Don't know if I have to create a new topic as it seems same issue for me :
Formuler Z8, ok since march.
I pick it up going in another place and then nothing. Nothing on tv. It boots but no signal. The remote is ok I can see the red light receiving.
I've changed the cable, the TV, reset factory, long press on resolution button : tv stay on a black screen.
Please help !
sounds silly but try another you never know
or Hdmi Port
1. https://support.formuler.tv/kb/article/10-…-2-error-on-tv/
2. https://support.formuler.tv/kb/article/179…irmware-1-4-80/
3. New Cable and other HDMI Port on TV
Already done that, I've read ALL the links before asking here. 3 hdmi on my tv, try them all, try another TV, another cable.
About the firmware, I don't know winch one is it, I can't see anything. Sound so weird...
It was ok, I used it on my TV, and on a friend's tv. I went daddy's home, try on his ancient tv and... nothing. Still then, unable to use it anywhere in anyway
What happens if you hold the resolution button, few times for 5-10 sec?
What are the resolution specs and settings with your TV and how different are they with daddy's TV?
Nothing happened when holding it a few time. Already done it before and after RF.
Don't know the daddy's spec. neither here, just it's 16:9. Can't see more in the settings. But the Z8 has been RF and resolution button done a few time so no matter the tv.
Once agin, it's booting well and remote send the signal to Z8.
I'm thinking about it since a few days now, can't figure out what the issue.
