  • Trailers are only available for MAC connections with custom Stalker (MAC) portal.
    Your service provider needs to customize their server implementation. It isn't something that needs to be "fixed" in MOL2 because it isn't a bug.
    Alternatively, you can ask your service provider to provide you with an XC API login instead of the MAC login.
  • I dont see the trailer on the VOD on my current server... PROVIDER is willing to cooperate and update.. he is using stalker based (MAC)
    how can they connect to the api for stalkerware(Infomir) for them to get that done.... ? if you can guide or send me a documentation that would really help
