Single EPG Program Listings Don't Match Other EPG Mode Program Listings
Please check to make sure you have selected "UTC" mode for your EPG in the Portal settings:
MYTVOnline2 > Main Menu > Connections > Edit Portal > scroll down > EPG Mode : UTC > scroll down > Update -
i have the same issue never heared about that utc will fix It. If i set to utc i don't get any epg data at all!
Mytvonline 2 EPG adjusting
Menu button - connections - choose the portal you want to adjust EPG -
EDIT - EPG MODE - change to UTC -
UPDATE (mac portals can try EPG mode -Normal)
Test the EPG.
If it's off a few hours calculate how many and go back to portal and adjust the EPG OFFSET
- 1 hour etc. or +1 hour etc.
UPDATE
Test again.
ALSO
if you dont have cathup on the service, then in MOL 2 live tv
Menu button
Settings
Disable "View cathup in Grid EPG"
If you do have Cathup in that service then enable this setting .
And try with XC api instead of M3U,
UTC IS set.
Catchup IS disabled.
Time settings in UTC mode are correct.
MYTVOnline2 > Main Menu > Connections > Edit Portal > scroll down > EPG Mode : UTC > scroll down > UpdateThat is highly likely to be a provider problem
