Parsing the package error
  • Hi, my iptv host is using his own app. But every time I download it I get the message : problem parsing the package error. What can I do , using Formuler Z8. Unknown sources allowed is on. I had it installed a while ago, I had to reinstall because of some EPG issues.
  • Check minimum Android version required by the app.
    Finally you should be using MOL2 to connect to your provider for the best experience
  • Until about 2 weeks ago it was working ok, and now, reinstalling it this parsing problem pops up. Maybe the software update has something to do with it? MOL2 is already in use with other provider and works fine.
    But this (spare) provider says only there own app can be used ( looks like Smarters). What I want to ask is why I could download that app some time ago but not anymore at this time because of some parsing problem that never existed before?
    Edited once, last by Wolfed12 (March 26, 2021 at 6:37 PM).
  • It looks like I am the only one with this parsing problem. How is that even possible, before the last two software updates this problem never appeared. Back to the factorysettings, I guess.
