Update: it seems to connect to wifi only after I disconnect the ethernet cable from the STB. Does this mean I can't have the wifi turned ON while the ethernet cable is plugged in? That's weird.
Hi folks, it works perfectly fine with ethernet.
Regarding Wi-Fi, it finds my SSID, password entered is absolutely correct, yet after a minutes or so it would timeout, then it says 'Couldn't find (my SSID)'.
I've already reset my modem/router and this STB. All other Wi-Fi devices are working fine.
The firmware has been updated right after unboxing via ethernet cable.
GTV ver. 9
Security patch April 5, 2020
Kernel ver. 4.9.113
Build PI20200514
