Firmware v.1.5.2 HOTFIX BETA for Z8 Pro, Z8, Z Alpha, Z+ Neo, CC released
Firmware Version : 1.5.0 HOTFIX BETA
WARNING:
HowTo Install:
Home Menu -> Software Update -> press "0227" -> Red Icon and Beta Test SW appear (right corner) -> Press Red Button -> Now is the Firmware and Software shown, press "OK" button for install.
Beta FW 1.5.2 discussions only in this thread here. Other open threads with Beta issues will be deleted instantly!
Change Log
Firmware Version : 1.5.2 BETA Hotfix
- FIX: Leanback Launcher crashes
- IMP: Set default player for MOL2 home screen channels
