Z8 Pro with ORBI RBK852 WIFI 6 router keeps disconnecting from wireless WIFI
  • Hi,
    I upgraded my router to ORBI RBK852 WIFI 6 and now my Z8 Pro keeps disconnecting from my wireless WIFI.
    I have a satellite installed all other devices connect with out any problems.
    If will connect and than all of sudden lose wireless connection.
    I have checked the internet speed which is 400+mbps.
    This seems like Z8 Pro issue.
    Please can Z8 Pro support help me resolve this issue.
  • Make sure you have separate 2.4G and 5GHz access points (SSID) setup on the router (and satellites)
    Make sure the Z8 is connected to the 5GHz AP
    Try to setup a static IP for your Z8
