How do you close running back ground apps? The way it worked on my formulerz7+ doesn't work.
I got 2 remotes with this new Box but I noticed the cursor button doesn't bring arrow on screen?
On the Z7+ when you were file browser say watching a movie from a folder when you were done if you wanted to delete this from that folder you would tap menu key then at the bottom you could select delete then ok and it would be done. I don't see an option to do this in the new F10 Box it is called media browser on the new box.
Can you download file browser for this box from market?
For any help or info
