This has probably been asked previously but I could not find it, but is it possible to load the BBCi Player or ITV Hub, C4 or C5 onto the Z10 Pro box?
BBCi Player
- Apps
- Z10 Pro
happyhotspur -
January 14, 2022 at 10:56 AM -
Quick search shows this results, not tested!
- https://apkpure.com/search?q=BBCi+Player
- https://apkpure.com/search?q=ITV+Hub
- https://apkpure.com/search?q=c4
Download to pc, unzip, copy on formatted USB Stick and install on box through stick.
or
Install Aptoide app from Market and search in Aptoide app for this apps and install directly.
Many thanks Sam really appreciated and will give it a go and report back
Downloaded Aptoide and then BBCi Player worked perfectly but no app found for C4, ITV Hub or My5
Re uktv
For last year I have been getting notifications from the apps you mentioned that man no longer supported on this device, and that I should contact developers for more information? BBC iPlayer works fine. I've been curious as to what is going on, is it specific to my z 8 pro or Android boxes?
happyhotspur. You downloaded BBC player from Aptoide and it works perfectly? How? I have done the same but cannot properly navigate through the iplayer screen as it "overscans" my tv screen and when I scroll using the arrow keys there is no indicator (change of colour or enlargement of an icon) to show me where I am on the screen, so when I press Select/OK I am not sure what I have selected. Which version did you downloaded, what type of TV resolution or formulate settings are you using do you have? In my case obviously the BBciplayer screen does not fit my Sony TV display right.
jkovac your correct it doesn't work I managed to download it and used a VPN and it loaded but as you say you cannot access any programs so it is a complete waste of time
