I notice that sometimes the box isnt responding well to the remote; you can see the little white light on the box registering the remote movement, but nothing happens.
This happens also in the mytv app when browsing through channels, but also in normal menus. It's only started to happen recently; before the last update (i think) it was fine.
I changed batteries on the remote, also reset box to factory but the problems remains even with fresh install.
I think this started happening after i reset the box; the screen on the homescreen kept flashing, looping and i couldnt do anything but hard reset it.
