hi when trying a 4k live stream getting error illegalstateexception on z10 pro max, my z8 pro plays the stream fine
anyone got a fix
thanks
anyone got a fix
thanks
This issue have been fixed few months ago , try to do latest software update
ye i’m on latest software mate
Could you provide a photo that shows the your software version ? if this symptoms persists after latest update, you will have to send it
to the dev.
You can upload the Image/Video file here: https://streamable.com/ > Upload file > Copy link > Paste the link with your reply.
Report a problem, send logs and write the tracking number when creating a ticket to the helpdesk.
Settings > Device settings > About > Report problem 2. Please create a ticket on our helpdesk: https://support.formuler.tv/home/
-> You can see the chat box on the right side
I’m getting same error on a 4K uhd stream
Pro max z10
Lastest software all upto date also
i have the same error. Already had the latest update. Frequentie happens aftershave pausing serie or vod but also at live tv
I have this too, but not always. Changing from group to another group, and then this happens. Rebooting the Z10 helps fixing the problem, but very strange.
Erik
Delete MOL2 cache and check if the issue remains.
Make sure to check with your service provider if there is any issue on that specific channel.
\I have this too, but not always. Changing from group to another group, and then this happens. Rebooting the Z10 helps fixing the problem, but very strange.
Erik
Same, but try to take a video next time when it happens again. You can upload the Image/Video file here: https://streamable.com/ > Upload file > Copy link > Paste the link with your reply.
