Hey all.
Ive been trying to record a channel while watching another. I swear this feature used to work but not anymore. Whenever I try to change channel it says "warning, now recording".
Any help is greatly appreciated.
Hey all.
Hi,kiwi, there is an article on the subject"Record one channel and watch another channel Mytvonline2", in the Quick guide.
You do need two connections of your service provider,in order to do this!
Thanks for response
The user assumes any risk of ban in this case! This depends fully from your provider and permission. Formuler is not responsible for any bans in this case. Pleas check this first with your provider before you use this feature with your m3u playlist.
Is merge possible?
What is with PiP?
All above applies to PiP (Picture in Picture) too.
Great,very clear explanation, SAM! ![]()
