Black screen Z10 pro
  • Hi.
    • Model: Z10 pro
    • Retail Box or Provider Box: Private box
    • Firmware version: Dono, the latest i guess.
    • MYTVOnline 1 / MYTVOnline 2 version:
    • Connection with provider:
    • Box connected with: Wifi
    • Did you factory reset your device? and when?: Yes, yesterday.
    • Picture url (only https):
    • Video download url (only https):
    • What issue(s) are you having? The picture goes black after start logo.
    • What was you expecting to happen? See the menu.
    • What happened instead? Nothing.
    • How can we reproduce the issue you are having?
    • What have you tried if anything to rectify the issue? Did a factory reset.
    Did update my box this sunday, after that update. The box kind of died.
    When I start it up the start logo shows, then nothing. The screen becomes black.
    I did a factory reset, but still the same.
    Is there anything else I can do?
  • Before the box died, did it ever load,and if so did Apps like YouTube work?
    Did you reset your router?
    Did you try ethernet connection?
  • Thanks for the replay.
    I had not done that. I have done now but still black screen.
    The box loaded until the welcome screen and then died after the reboot on the upgrade.
