Hi, I have an old Formuler box, think 8 years old, looking to upgrade - wondering if the Z10 is worth above the Z8, some people still prefer the Z8. Plus any reliable iptv providers with multi screen options? Thanks
Z8 or Z10
- Hardware
- Z10 Pro Max
Rene -
October 31, 2022 at 7:17 PM -
If you need new box than buy the newest model Z11.
That's a hard one,the z8 is more stable than the z10,the z11 is jst released so it will be buggy as hell for at least 6 months,iv already got a z8 and jst returned my z10 as I only bought it last month so when I seen the z11 was released I sent it back and will get the z11,the z10 is a great box and I'd have kept it if the z11 wasn't released.if I was you I'd go for the z10
Thanks, other thing is, a good smart tv will do the job as well? Smarter IPTV app?
Well depends. In reality yes, even though barely. But with a box the experience is just on a whole different level. With the Formuler box the thing loads up at once (instant from standby mode) and the channel zapping and scrolling is super fast. Add to that functions as recording, gui friendly and easy to scroll through vod
I had an app through smarttv before and got the formuler box because it took som time to scroll through the groups and haven’t looked back once. The difference between the two are light years away
Yes I was thinking the same…
It depends on if the provider you use has alot of channels and how much memory your TV has,I used to use my LG b8 old smartiptv app,and it's OK but even a firestick running tivi is another level
