Speedtest by Ookla apk not working on Formuler z 10 pro max
  • Hi
    I had this Speedtest by Ookla on the Formuler z 10 pro max for maybe a year and today when I tried to use it qouldn't work. You have to use the arrow mouse for it but when I clicked it showed the arrow but wouldn't work on the apk. like it used to so I tried the arrow mouse on mytvonline and it opened it so not sure if this has anything to do with last update.
    I downloaded latest version but that wouldn't even install said apk. not installed any idea? I have it on my form z 8 same ver i had on f 10 pro max it works on old box.
    thanks
  • Hi
    thanks
    Dean Mills , maby i can help you. Check your inbox for info😃
  • Hi
    I don't know it isn't in the market place here in Canada or at least not on my f z10 pro max box. I had the speedtest app on the box for about a year worked fine then the other night went to check it and the arrow mouse it would show the arrow but when you clicked it wouldn't do anything so I tried the mouse arrow on other app worked fine so figured it was a problem with the speedtest app so I uninstalled the older version and put on the latest one I got from internet as it wasn't in the market place anymore at least on my box. When I tried to install latest version of the speedtest apk. it says not installed every time I tried it. Another member on here sent me link to one from market place so i tried to install it and said same thing wouldn't install. So not sure if this is a problem in North America it seems since last update to the formuler box.
    Makes no sense to me .
  • I just checked on marketplace on the F z 8 box and the Ookla speedtest version 4.1.9 is on there but not on the marketplace on the f z10 pro max. I think they must be having a problem with this app working on the F10 pro max now it used to work till last update. Hoping somebody can figure it out why it used to work and now doesn't and why it isn't in the market place on the f 10 box?
    Go to user market inside market. Pincode 0852. There u can find ookla
  • Okay that isn't the main site on the market if you go into market on f z8 box the ookla speedtest is right there you don't need to go to the other link 0852.
    I downloaded the newest version right from ookla own website but it won't install on the F z10 pro max box. I had the Ookla speedtest on this F z10 pro max for about a year it was after the last foremuler update that it stopped working and you can't use the arrow mouse on it.
    What version did it give you from the pincode 0852 of the ookla speedtest.
  • Hi
    Installed that version it works but without the mouse arrow. have to try and use center keys 2 clicks on left then up then okay to get it to work where it use to be able to just select the arrow key then arrow would appear on screen to make it easy to select setting etc. now the arrow won't work and if you try to put latest version of the Ookla speedtest on this box it won't even install it. I don't know why when I had another version on the box that worked for over a year with the arrow mouse.
