No switching to next season on VOD TV series while you are on next season? He stays on the season 1 episode? It's the same with every TV series. Problem in MYTV Online 3? Solution?
With MyTV Online 2 on Z10 pro max that was no problem.
Have you checked with the latest version?
with latest MYTVOnline 2 : 11.1.40 Hotfix update VOD bug is not fixed?
Tested now with my sub, works perfect. The Episode ends, window with info to start next episode or leave it like it is (automatic start of next episode including 10 sec circle) appear and next episode starts automatically when the circle is full.
What kind of portal or M3u Playlist are you using? Stalker MAC, XC API Portal or m3u playlist?
Hi Sam, thanks for your response. I am using XC API Portal and if I want to switch to next season for example season 3 the list of episode stays on season 1 see photo.
Test was also done with XC Api Portal and i believe you. Tested with some other external player (VLC or MX Player)?
MX player en VLC as an external VOD player but no success with switch TV series? With VOD movies yes
Interesting that VOD works and Series not, the function behind is same.
I will not say it could be provider depended but did you maybe try some other trial account from other provider? Would like to know what is the reason for this.
@Others
Someone else with same issue on Z11 (exactly same!)
Hi Sam, I contacted the provider he said the problem is not with him. it may be correct because I did a test on iptv smarters and the switching goes well, see photo. Could it be that the shifting issues are with MOL3?
@Others
Hi
Same here (if I understand the issue well): VOD Series: next episode in a season is ok (forward or autostart), after the last episode of a season I have to go back and manually start the 1st episode of the next season.
Please do me a favour and change your system + MOL3 language to English and try again, just a some idea. Remembered something similar from past.
hi SAM
Same problem with english languages (tried system with UK- and USA-english) ; works fine in TiviMate ; also tried in MOL3 with VLC, MX, Nova and X-Plore: all not working fine (not even possible to go to the previous or next episode within a certain season), but that's not the discussion here (as we're talking about the MOL3 standard player - which is my favourite, btw).
Please contact me through pm, want to try something with you.
Hi, with new update switch works perfectly. Fixed, thanks guys.
@Others
Me! I got exactly the same, cannot switching between seasons since I got the Z11 Pro Max ![]()
