Where can I find the option to switch portals? In MOL2 it was in Connections however I don't see it in the new Content Manager. Please advise.
Thanks.
Thanks.
No need to switch portals in mol3 there are streamlined/all loaded at same time
Interesting concept. Thanks for the heads up.
so why is it I only see 1 portal on my epg where are the others??
Change to other portal channel and you will see it.
how can i add another portal in mol3?
Content manager
There seems to be NO WAY to switch between Portals. Can Someone PLEASE give some details and insight into this. Simon ?? Where are you these days ?? No help from Korea head office lately
Someone PLEASE post how to remedy this asap
I can go to Content Manager and see all the Portals but there is no CONNECT feature.
MyTvOnline3 is a MESS compared to previous version 2
How Can I switch between Portals ?? There is no Connections Tab in Settings. And in Content Manager it shows 6 Portals but no way to Disconnect or Connect between them.
Install beta update and check Enable/Disable in Content Manager > Content Sources
This is not user friendly!!! I have 4 portals and need to deactivate all of them except the one I'm actually using. Totally backward thinking. OK to load all of the profiles, but then a 'connect' button is needed for which one you actually want to use. Crap compared to MTO2
I don`t understand what your Problem is and crap is the way how such postings starts, exactly like yours! First post and straight away all is crap
Read Forum Rules first!
1. You have the possibility to add more Portals and after that they activated.
2. You don`t want to use each one at same time, you have the possibility to deactivate such portal.
3. Later you can activate same portals with Enable Button. Enable /Disable button are present! Except you want such Buttons that recognise what you think,ideally and instantly do what you like ... Sure, that would be very user friendly.
So tells us what is wrong with this? What do you expect and what triggers you?
