Different FPS
  • I currently have 2 boxes, the Nokia 8010 and the Formuler Z11.
    The Nokia runs Tivimate.
    On Formuler, Live TV films/shows only run on 25 FPS via MOL3, series and films (VOD section) at 50 FPS.
    On the Nokia 8010, Live TV films/shows run at 50 FPS, but films and series (VOD section) only on 25 FPS here.
    I wonder how the mixed difference comes about even though everything is the same provider? :thinking_face:
  • Same TV?
    My tv does every refresh rate, but always go to 1080p50hZ for both 25/50fps material on formuler no matter the iptv app used. VOD is usually 23,976 or 24 and MOL3 gives both refresh rates correctly, also works in kodi but with a twist because on Kodi always change resolution to the best, so it will change to 4k no matter source resolution. MOL3 respects source resolution.
    Make sure in MOL3 you have auto frame rate enabled in settings for both vod and live tv
    Edited once, last by z11pronotmax (December 31, 2022 at 4:20 PM).
