Hi, I have 6 gtv running and 5 z10 pro max all on stalker portal
The issue is that all the gtv display the failed to load vod data, I have reset the box/boxes issue comes back. I have tried m3u same problem I have cleared the cache on mytvonline 2 delete the portal info readded it. I have a 2gbs connection hardwired, I've tried wireless and nothing seams to work. I will also add the both the box software and remote bt1 are up to date with current firmware/software what am I missing????? All the z10pro work flawlessly
