Not possible to customize Favorites list?
  • I was so relieved when i saw the fact that Z+ neo actually SAVES the favorites list upon disconnecting the device from the outlet!
    However, is there a way to customize the favorites list? I just added a lot of channels, but somehow, a channel was not added, and when i added the missing channel, it is of course added to the bottom of the favorites list. Must i recompile the favorites list all over again or is there a way to MOVE the channel longer up on the favorites list? I hope there a way to fix this...problem.
  • Use Favorit Manager to add new channel and with longer OK press you can move, delete and arrange your favorit channels.
    1. Favorit Channel adding: Channel list->Category List-> once again left arrow and "My Groups" appear -> Choose or create your Favorite Group -> Add your Channel from preferred Category.
    2. Arrange: Choose your created Favorit Group -> Mark Channel inside this Group -> Press OK Button for 2 sec. -> now you see up and down arrow on right side from your channel name -> channel is chosen and can be moved up or down (important if you press arrow right the channel will be deleted) -> move to preferred place and press once OK button again. Channel saved on new place.
  • External Content www.youtube.com
