Hello everyone,
I have probleme with my Network Storage with Z11 Pro Max (I have also with Z10 Pro Max same probleme).
I can mount my Network Storage manuel but if i reboot my Z11 Pro Max and don't mount my Network Storage on startup, i have enable "Reconnect on Startup".
Later i found out that my NordVPN unmount my Network Storage.
If i disable NordVPN on start, Network Storage will mount as normaly, but when i enable NordVPN than my Network Storage will unmounting.
Someone know about this probleme and what can i do ?
Is happend also with Z10 Pro Max.
My Network Storage is connect to Synology DS1819+
Thank you for your help.
Sorry for my badley english
