Google play
  • So, really stupid question here. When I try to log in to the Google Play store, I can't move my cursor off of these 2 options to the next button.
    What is the simple step that I'm missing?
  • Not a stupid question at all.
    You may need to enable the mouse cursor mode on your device to get past this screen.
    Make sure you have mapped the mouse cursor function to one of the "dot" hotkeys on your remote.
    You can accomplish this by using the Formuler Remote app located on the home screen of your device.
    If you don't see the Formuler Remote app on your device, install it from the Market app on your device.
    After you have confirmed that the mouse cursor mode is working, go back to the Google login screen and activate the mouse cursor so you can press the Next button.
