I am unable to pair a Legacy remote to my Formuler Z10se box. The remote that is paired to it at the moment is faulty, so I bought a new remote. I have tried all the suggestions that I could find online. Is anyone able to advise me please? Kind regards, Kelly
Unable to pair Legacy remote & Formuler Z10se
- Accessories
- Z10 SE
KellyM67 -
June 12, 2023 at 3:03 PM
There are old and new versions of the legacy remote as well. If you purchase the old version, it will not pair with the Z10 series.
Is the letter '02F9' written in white under the remote?
When you press a button on the legacy remote, does the LED on the Z10 SE blink in response?
There is no pairing process for legacy remotes. Just point the remote at the front of your Formuler and it should work.
Maybe you didn't purchase the correct remote or you accidentally purchased a fake Formuler remote.
Share a photo of the remote you are trying to use so further assistance can be provided.
This is a fake Formuler remote. you must request an exchange with your seller.
I will do that. Thank you so much for your help. Kind regards
Today I bought another remote from another dealer and I can’t get this to work either?!?
Unfortunately this remote is also fake. If you don't mind, please share your country so we can recommend another seller.
