How to reset to fabric settings?
  • hi i did a facttory reset in from the menu ,and afterward i installed mol2 ,but now i cant connect to myiptv ,i only get the radio stations,it works fine on an old box?
    did i do something wrong,is it a necessity to reset hardware first by using a clip in the infrared hole and first then do resetting in the menus?
    peter
  • Hi,what message do you get (if any),when you try to connect to your iptv?
    How are you connected,MAC,XC or m3u?
    Do you get error code3?
    I guess SAM would suggest hard reset,with the pin.
    Before you do it wait for his opinion!
  • I guess SAM would suggest hard reset,with the pin.
    Good thinking Henkie :thumbs_up:  :winking_face:
    Yes, please factory reset again this way:
    External Content www.youtube.com
  • Glad you agree SAM,personally I always have regarded the hard reset as an ultimate resucitation attempt,but i think thats just a feeling I have,when all other options have been tried out. :smiling_face:
