Hello all,
I've got a problem with my Z+ Neo box. The PQ Settings menu keeps popping up at random intervals despite the remote not being used.
The menu concerned says:
PQ Settings
Display Mode: Standard
Imprex Engine: Full Screen
It's basically the menu which comes up if you hold the V Format button on the remote, except the remote isn't being used at all.
I've tried taking the batteries out of the remote and inspecting the remote/buttons and it still continues. As far as I am aware, nothing else could be interfering with it. The box is connected directly to the TV via HDMI.
It only seems to do it when watching the VOD section on MyTVOnline2.
Any ideas how I could fix this would be much appreciated.
I found the following closed thread on the subject but it was closed and I'm not sure if it was resolved.
PQSettings just keep popping up
On my Z+ Neo the PQSettings just keep popping up while watching a tv show without touching the remote and I've no idea why, any ideas ?
Thks in advance
