z11 pro home screen apps (move, hide etc)
  • ok, i am very new to Android TV as well as Formuler (I actually WON a z11 pro in a contest!)
    I figured out how to create a set of apps (group A), and move the apps around in that row..
    1) is there a way to move a row up or down? or hide apps? I dont like the APPS row being on top.. I'd rather have my group A of STREAMING apps on top..
    2) is there a way to hide an app I dont/wont use often? Like in my Samsung TV, I can just put the apps I want in the popup.. but the rest are still there in the ALL APPS
    THANKS!!
  • Home Menu -> Launcher Settings -> App Groups
    Here you have Group A and B
    Select in Group A your Apps you want to use always.
    Select in Group B your other Apps.
    Now you have two rows.
    Go to Locker and activate lock for chosen Apps to hide them.
  • Is the Locker Room functionality available on the Formuler Z11 Pro BT1 as I am having difficulty locating it.
    Thanks for your help.
    Stuart
  • If app is placed on homescreen. Hold ok, and then you can move left or right. And or click on remove to remove icon from app.
    Click uninstall to delete app from box.
    Go the the upper left you get extra options to add a row or delete a row.
    Edited once, last by Lucky13 (December 23, 2025 at 10:48 AM).
  • Hi ...
    Thanks for your reply.
    What I am trying to do is hide applications from the main menu to the locker room but I am struggling to find this functionality on the Formuler Z11 Pro box
    Thanks for your help and assistance.
    Stuart
  • Hi ...
    Stuart
    Sorry i don't use it. I know it's at settings menu somewhere.
    But i bet you find it out! Goodluck my friend.
  • Thanks for your hints on how I could hide and unhíde desktop applications via the Locker Room.
    Have managed to find this application functionality on my Formuler Z11 Pro BT1 have it working ñow.
    Best wishes, have a Merry Christmas and Happy New Year.
    Stuart
