Live channel problem
  • Hi all,
    New to the forum as I have never really had any problems with my Formuler boxes before.
    Have the Z11 pro max now, and am frustrated trying to figure out why I can't seem to watch live channels any more. VOD and TV series work fine, same does timeshift on the live channels, but live channels themselves only gives me HTTP error 404, contact service provider.
    Have reset to factory default and get the channels working briefly, sort out the channel lists and favourites and so on, then when I reboot the error comes back.
    Driving me crazy at this point, anyone have any ideas?
    Cheers,
    Sean
  • Hi
    When you press menu button does the live tv section come up or is it absent?
    Did you do the recent beta update for z11?
    Did you contact your service provider,and if so what was his reply?
  • Hi,maybe you can try uninstall mol3, and reinstall from Market,then restart your box,see if it makes any difference?
  • Change your protocol to some other and try again (Stalker MAC/ID, XC Api or M3U Playlist).
    Yesterday there was an update to the Z11, Firmware 11.2.9 and MYTVOnline 11.2.34 and that seems to have fixed the issue!
    I haven't changed any settings, but now after the update the live channels are viewable..
    Glad it seems to be fixed, but funny I was the only one reporting the issue. Also hate it when things just "fix themselves" without finding the cause.
  • I'm having the same problem. I can connect to the IPTV service and watch TV Series and VOD, but Live TV will not stream. I get the error message 405 - unable to open stream. I updated to the newest firmware release v11.2.10 and MOL3 v11.2.1 yesterday and it has caused me many problems. Could not connect to internet via WiFi even though connected to the WiFi. But could via ethernet cable. Factory reset fixed that. Then the problem with Live Streaming. Nightmare! I have reinstalled MOL3 via official update via the box but no change.
