Is it possible to run multiple IPTV apps, from the same IPTV subscription, on the same box?
  • Hi everyone,
    First post here. I have a Z11 Max Pro, love it. I of course am running MyTVOnline 3 with an IPTV subscription. I was curious to try out TiviMate to compare the interface and navigation vs MTVO3, so I went to the Google Play app and downloaded TiviMate.
    I then tried to input my Stalker portal info in Tivimate, but I kept getting an "error" message indicating "please contact your provider to register the device". However, according ot my service provider, since my device and service is already registered to MTVO3, I can't add it to Tivimate. He said I'd have to unregister MTVO3 in order to register Tivimate.
    Has anyone else tried to do this, and if so what was your experience?
    Other options I'm curious to know of:
    - I have a Firestick, can I apply my existing subscription to that as well, and try Tivimate on there?
    - Could i purchase a second IPTV subscription and use that to enable Tivimate on my Z11 alongside MTVO3?
    Thanks in advance for any insight you guys can provide!
    Cheers,
    A
  • Hi! I try it to I pay for Tivimate too...i try it in stalker and he does'nt work... Maybe we need to enter device id 1 and 2 and duplicate alls others infos from mytv3. May be the server block the clone box in stalker tivimate mode. i will make a new test. :smiling_face_with_sunglasses:
    Stay Tune,Return after the EPG LOAD! :smiling_face_with_sunglasses:
    Nvidia...Tivimate...good choice!
  • Stalker sub. is only registered with one MAC/ID. If you use MAC ID for MOL3, then you can use XC Api login on Tivimate. This of course only with one app at once, never both at same time. Please note, the Provider can ban you if you try to use single sub. with more devices at same time.
  • This is my first time on this site, the question to the Formuler people .... why can't you implement the ability to sort or manually arrange the channels, guys ... it can't take more than a couple guys coding and looking at what Infomir did .
    I like the box, but myiptvonline3 need some Ukraine programmers on it .
    Cheers
  • First time and already offensive! If Infomir is so good for you then use Infomir, Formuler is Formuler and do not need any other programmers!
    Create so much Favorit Categorys you want and put your channels you like inside, problem solved!
