I just installed a Z10 Pro at a dear friends place and I noticed that when we shut it down (sleep mode) and wake it up a little while later, it goes to the home screen instead of the last channel that we were on when it went to sleep. It does not go through the boot menu (displaying the "Formuler Z10" boot up). It just goes to the home screen, where we now have to select MYTVOnline2 app to get back to the TV.
At home I have the Z8 and it will always wake to where it was before it went to sleep. Whatever channel I was on. It doesn't matter if a few minutes has passed or a few days since I turned it off.
I have tried going through the Z10 settings to see what is causing this. I have also tried searching through this entire web-site and Googling for any assistance.
Believe me, I would only create a new post asking a question as a last resort, to try to find an answer.
I have tried setting the default startup app to MTVO2, and that sort of works in such as it still goes to the home screen then automatically goes into the TV app, but it still has to load it as if it is the first time that you went here. My Z8 at home does not have the startup app selected, it just goes to the last channel when you turn on the box.
Is the Z10 setup differently that it will only wake to the home screen?
Thank you
Paul
