Z11pro max
  • Hello,
    if we speak about Z11 pro Max-BT1 the specs are different: Newer chipset, CPU and GPU, Bluetooth Remote and MOL3.
    If it`s worth to change must you decide.
  • Yes, ...... but only if you like a better and more functional MOLTV3 app, backup of your settings, asynchronous multiple subscriptions, a cleaner and more friendly UI, and a big smile on your face all day long! :smiling_face:
    Go for it!
    Cheers!
    Go for it!
    Cheers!
    Hi morden,i reacted with confused emotion to your post because i guess you are a late adapter to the Z11.
    On the other hand i bought my Z11 straight at its introduction,and it was far from Plug&Play in the early stages,problems like epg,network connection,VOD loading etc were all corrected in subsequent updates.
    For me the Z11 has since the last updates reached toplevel and ready for daily use,so i can now support your opinion to "Go for it"
    The speed and Picture Quality are definitely superior to the Z10,so the decision to upgrade would be an easy one now :grinning_squinting_face:
  • Hi morden,i reacted with confused emotion to your post because i guess you are a late adapter to the Z11.
    I absolutely was a late adopter (about December 2023) as that is how I work. I never do early adoption because I spent 50+ years as an IT pro and I had my fill of debugging other people's software. :grinning_squinting_face:
