Formuler z10 se - experience & questions
  • Hi,
    I am a happy owner of a Formuler z10 se device.
    Before formuler i used the Strong Leap-S1 streaming device with the iptv smarters pro app and that was a poor iptv experience! Iptv was unstable and slow navigation, i'm glad that in the end i spend money on a formuler box, the MyTV Online 2 app has noone of the instability i have previously experienced and navigates quickly.
    Now there are a few questions i have,
    1. Is casting by default enabled? If yes how to turn it off? I am at a shared internet network and do not want casting to be on, it enables other people to cast their stuff to my device.
    2. How do i remove apps from my home screen, i want youtube gone because i use SmartTube.
    3. Enabling IPv6 splits my download speed in half, normally i get around 80Mbit download, with IPv6 enabled i get 50Mbit max. No VPN turned on.
    4. Is it normal that sometimes the EPG timeline doesn't line up right? Some channels seem to line up correctly but others don't, i played around with the EPG Offset and Mode but i never seem to get everything synced up perfect.
    5. Recommendation to add Mullvad VPN to the Market app,
    It is a very affordable vpn service (5 euro/m) that works with fhd quality streaming, they offer a direct .apk download for their app at the official website. I sideloaded it and it works great, it would be nice to see it by default in the Formuler Market app, sideloading wont be needed and everyone can enjoy affordable vpn.
    Greetings, Erik.
  • 1. No, is safe
    2.- Home menu -> Launcher Settings -> you can arrange the app icons etc.
    - Removing app from home menu -> home menu -> Settings -> Apps -> See all apps -> chose app -> delete or deactivate -> restart the box.
    System apps can not be deleted and Youtube is system app, you can only deactivate.
    3. Better deactivate IPv6.
    4. Yes it can happen. EPG content and results depends very much on the provider.
    On your side you can only set right parameter for Data, time, GMT+ etc. to be sure.
    MOL2 Menu -> Connections -> Portal -> Try also to switch between Normal and UTC - EPG Mode. test which works better. Offset settings only if really needed.
    5. Thanks, but esp. VPN Apps should be each time sideloaded from official website because they change frequently Version. No and Formuler Market is then not up to date each time when new version is released.
