Hello- When I have my Bluetooth sound bar connected to my GTV, and while using the MyTvonline2 app, random channels will come up with Initialization Exception and not load. Once I turn off the Bluetooth they connect fine. I have tried other apps, to make sure it wasn’t the channel and they work fines
Initialization Exception- with Bluetooth conneted.
- MYTVOnline2
- GTV
woofer21 -
April 17, 2024 at 11:33 PM
- New
Please upload screenshot from error message and post your config.
I have uploaded a picture. What config are you looking for.
- New
reinstall MOL2.
How do you reinstall MOL2?
Probably the same as on z10&z11.
Homepage>settings>apps>mol2 >uninstall.
Then reinstall mol2 from Market
There isn’t a market on the GTV.
Question for you Lucky133,how do you reinstall mol2 on GTV?
- New
Home Menu -> settings -> apps -> mol2 > "uninstall updates" this will change MOL2 to factory settings, then check after this "software update" if you need to update or not. That`s all.
Is this what you described above also possible on z10pro/mol2?
I understood that all Formuler boxes ,starting with legacy models,have Market?
- New
This is only for Android TV GTV Model that use Play Store directly as Market. AOSP Boxes have known Formuler Market.
GTV works in few cases different like other AOSP Boxes.
So I did uninstall updates, then it prompted me to install updates and I did. And I still have the same problem
- New
What happens when you delete your portal and create new connection?
I just deleted my portal and created a new one and it still happens. If I turn off my Bluetooth sound bar, the channel connects immediately.
- New
Can you tell me how your devices are connected with each other? Box to TV and then through arc to Soundbar or Box to Soundbar and Soundbar then to TV? In which config does this error happen?
Like sam.said, via software update.
Set up is-
GTV box to Tv via HDMI.
Sound Bar is connected to GTV via Bluetooth. -
- New
Try this way:
GTV to TV and TV to Soundbar over HDMI ARC with passthrough. Soundbar with GTV over Bluetooth is not good solution.
I have been running Bluetooth to my GTV since I first got the GTV and have had no issue until the last GTV system/software update. Also I do not have hdmi on my soundbar.
me too since the last update, the images stutter several times a day, forced to restart Mol2 to resolve. When will there be a new update? Is Gtv already obsolete?
