MYTVOnline 3 double VOD connection issue.
Got the Z Mini and for the most part everything is going well. Quite different from fire sticks and the shield for sure.
Anyhow, I've loaded my provider info into mytvonline3 and everything loads fine. Live channels play as they should. VOD/Series do play as well BUT they show up as my account using two connections for each movie or episode. Backing out of the player only closes one of those connections and the 'phantom' connection stays running until I force-close mytvo3.
I went ahead and installed a smarters variant as well as another player just to see if this was an issue with the provider on this hardware but they didn't have the 'phantom' connection problem.
Is there something that I can adjust to correct this issue or is this something that will require an update on the mytvo3 side?
