Z 11 pro max BT1
I can't find the HDMI port specifications anywhere. is it a 2.0 or 2.1?
Why one of the crucial specifications when choosing a TV box is not reported on the manufacturer's website?
Z 11 pro max BT1
It's probably HDMI 2.1 but not HDMI 2.1b if you know what i mean.
I'm waiting for the official response from someone from formuler because it's more likely that it's 2.0b and not 2.1 or 2.1b
On internet i find more sources that its hdmi 2.1.
On all they say its hdmi 2.1.
Not 2.1a or b etcetera
Z11 has support for gaming mode (ALLM) and that's an HDMI 2.1 feature.
I need the manufacturer's specs, not guesses
Z11 support 2.1.
Z mini support 2.1.
I m sorry, did mistake in hurry and edited now my post. It is 2.1, sorry.
I saw a post where an admin replied to a forum member that the z11 has HDMI 2.0. If I find the answer I will post it here. I'm more confused with your first reply and the other post I found here
Like i wrote, my bad. I asked Formuler directly and they confirmed it is 2.1. So the older post in other thread will be also edited.
If z11 support all hdmi 2.1 specs is something else, i think not all of them, like in case of 4k 60hz from older post.
I second what SAM is saying, it must be HDMI 2.1 otherwise you couldn't have gaming mode (ALLM) and if you don't get 4k 120HZ is because Android 11 can't pull it off, it's software/firmware limitation. If or when formuler upgrades to Android 12 you will probably have some enhanced stuff appearing in settings. But i'm not sure if formuler has any intention of upgrading it to Android 12 LOL
