When I want to see 4K live tv channels I get a message “IllegalStateException”. I use the latest software version .10.10.57. Is there a issue that I can fix?
Illegalstateexception for 4K live tv
- MYTVOnline2
- Z10 Pro Max
havro2023 -
July 13, 2024 at 4:58 PM
seems your provider use some different format or codec than usual for 4K streaming and this collides with MOL2.
Which protocol is in use, Stalker MAC/ID, XC Api or M3U Playlist?
I use m3u playlist. The 8k playlist from my provider works fine but 4K get the error message for 1 week now. A reload of the playlist doesn’t fix the problem.
Try also to make a new portal.
Not as m3u, but as Xtream Codes.
Url, username and password.
Most providers use h264 and h265 codecs. Its most supported, so strange that they use other codec.
I’ve deleted the portal and made it again with Xtream Codes. Now it works fine. Thanks 👍
Wel done my friend.
Good job.
Have a great experience with your formuler device.
