Aspect ratio broken with update from this week
  • Hi all,
    Since the new update I’ve been experiencing issue with aspect ratio. The aspect ratio option Original seems to function the same as Full. So a movie in 1920x800 for example gets stretched to full screen when using Original. Need to manually adjust the ratio now each time. Anyone else experiencing this and perhaps know a fix?
    I reinstalled MOL3 and checked various settings but no difference unfortunately. Very inconvenient bug as the aspect ratio syncs over Live and movies/series, so a lot of manual adjusting that needs to be done…
  • Did a factory reset but no luck either. No one else experiencing this? Was working fine before, so surely something went wrong with the update?
    Real bummer because many movies/series have aspect ratios which I can’t manually select so will always have some stretch now
  • Managed to fix it in the end. I installed MX player and tried that for a bit; audio and subtitles weren’t working, so switched back to default and all of a sudden it was fixed…
    Still very weird bug and hope it doesn’t come back. And if anyone else is experiencing it, there’s you’re fix I guess
    I use also mx player. No problems at my side my friend.
