1. Since there is no Live tv button on remote so how do I go to Live tv?
2.How do I access VOD?
3.What is User Market (yellow button) and how do I access it. It requires password.
4. Which remote button to use in order to Edit Portal URL?
Z7= problems
- Frage
- saaki
First of all tell us do you have buy retail box from store or from provider directly? There are differences!
Retail box have no limitations and need passwort only for factory reset. Provider sold boxes are already set with some limitations, closed [lexicon]settings[/lexicon] and passwords, depends all from Provider and how they set them. In this case please contact your provider.1. If you on Home screen then you need only to press VOD/LIVE Button. It works...
2- Depends where you are. On Home screen - MTVO Icon -> after MTVO loaded -> Menu Button -> then VOD. If you are in MTVO then only Menu -> VOD
3. Is App Market for Install if you don`t use Playstore.
4. There is no Button for this action. MTVO-> Menu -> PortalsPlease also look video Instructions, is helpful for use with Z Boxes -> Formuler IPTV Video Anleitungen / Formuler IPTV walkthrough videos
3) If in Market, press Yellow button on your remote, then enter this code 0852.......... suprise suprise
It is a retail box from a store.On Home screen I do not see any LIVE or VOD button on this Remote.
Every time I have to click Mytvo icon to go to Live tv where it connects the server.
Is there any way that you can set up to go directly into Live tv.?
Also how do I recall the previous channel watched? I am not talking about history of channels watched.There should have been a button on Remote .I have Buzz XPL2000 which has LIVE, VOD AND RECALL buttons on its Remote. Any chance that you can assign any key for this function in future update?
Another thing, I am trying to install Pluto tv app free but it keeps on saying that " download the correct version from Play store" I am downloading from Play store but it does not install.Please check it. Same is the case with Rabbit tv app.
I have asked too many questions.Sorry for that.
I can access USER MARKET by entering 0852.Thanks for that. -
Hm, something is here wrong. Please look on the picture and tell me do you have the same RCU from your Z7+ box
No it is not the same.
I had bought this box from your contact in Toronto.He had called me after my email to you asking for where I could buy this box in Toronto Ontario.Can you replace this ? I would very much appreciate
Please help me .Or ask your supplier to replace it.
Thanks for your help. -
I`m sorry but i can`t replace anything, this is only support board, for replaces you have to contact your dealer. But first i have to ask Formuler what kinde of RCU`s are now delivered with Z7+ for all, because my box is pre series box and could be different then final boxes in store, in this case the rcu.
I would wait for your info.
Can I ask Formuler.TV if they can help me.I
would pay for new Remote
Can you please ask someone who can resolve this.
Thanks -
I got answer and picture from Formuler. Please look on the picture, this is the RCU delivered with Z7+ box, right? There are all Buttons like VOD, Live and Group usable, same like with my other smaller remote!
Later i will come back to your questions, but first let us clear the remote matter.Is this the RCU you got?
No mine is different
Top line vformat red power Resolution
Under 4 color keys
F1 F2 F3 F4 no live void or vformat
Under these f keys are
Mute playlist sleep cursor
Do you think those 4 F1-4 keys need program in programmed
Thanks -
Could you please upload small picture (200kb) in Attachment, need to see it.
Here it is
I cant open 0852.
cant connecting market server -
Saaki..
U sure you got an Z7+ box?
because your rtc is for Z / Z+/Z prime versions.. -
Yes it is Z7+
Ok, then contact your dealer and let him know you get wrong RCU and want the rcu like on the picture in my older post.
Only for Info: If you use Android phone you can also install Air Sync Remote-Z and control your Box with your Smartphone, streaming and Mirror controll on Smartphone is also possible.
It`s nice App and each Z owner should try it. To find on playstore, click on url -> https://play.google.com/store/…ys.formuler.airsyncremote -
Is it possible this remote is for the North America z7+?
I am asking because I got the same one as Saaki and got the box from Canada Amazon.Cheers.
Yes it is, for North America and Canada, i posted this already in another thread.. The shown RCU on my Picture is EU Model. The Buttons F1 and F2 have same function for LIVE and VOD, only other description.
i wonder why the rcu is different between the eu and na versions?? can we get the eu remote for our na boxes??
- shi_thead
Must honest say, i don`t know really. The answer i became was N.America Distributor has different specs. thats all. Maybe it was just short decision between Distributor and Formuler before ordering, sorry for not have better answer.
