Insert epg data line
- Z11 Pro MAX
- MYTVOnline3
Humaxima -
November 2, 2024 at 10:28 PM
Normally when you add the m3u line.
But why not use from the m3u line a xtream line?
Fill in url at portal
And then the username and password from the m3u line.
You got everything in one then.
Display More
I’am using the portal option. It has worked fine, but suddenly i have no epg information.
And because its not working the provider gave me a epg line. (Looks like the m3u line)
In Smarters i can insert a epg data line, but i dont see it in mytvonline.
Should be there if you make now one.
Otherwise make a private conversation with me https://www.formuler-support.tv/conversation-add/
Add at Participants my name lucky133
Add your m3u url and i make a xtream codes login for you. tomorrow
I’am already have the xtream codes login. And the epg has worked fine till a few days ago.
(Its looks like since the wintertime in NL)The problem is i see in stead of epg information “ no information” behind the channels.
Is it a bug in mytvonline?
My old device had it too last year. The provider didnt change it or so after wintertime. So my epg was wrong
you can try epg offset -2 hours.
Hopefully it solves your no information.
But if you check your epg. Is everything gone? Also yesterday? It so, contact provider.
I tried your advice but didnt help.
The last time i had the same problem, we find no solution (also the provider found nothing).
But after install a new account the problem solved. Is it possible that its a account issue?
Did you ask your provider to "reset" your line?
I thought so but i’m just asking to be sure
Did you apply the usual measures in case of no info epg;
Content Manager>Content Sources>sub>show hidden info>set update interval to 3 hours>save.click on epg update in CS,it may take a while for the epg to populate!
I tested a new line and the same epg problem.
It must be a bug in mtvonline3.
What can i try more?
Try uninstall mol3,and reinstall from Formuler Market.
Now i have the same account with another url on the same server and epg is working.
Could it be that apps have trouble with some url for epg?
Difficult to answer,however if epg is working,dont look back and enjoy it
Could be.
Sometimes what you did helps like you see.
Good job my friend
Guys thanks for your thougts!
No, because it was your subscription issue from your Provider otherwise the new login data/url would not show EPG correctly too.
I should ask also tomorrow new url.
I think we have same provider😂
Haha, success
Haha, success
I changed url and epg is back again also.
Its weird and its a provider issue, because suddenly none of my devices/apps had epg.
Provider issue yes. Can happen😉
