how do I remove notifications after I read them?
Notifications
- Z11 Pro MAX
- MYTVOnline3
66fbren3010 -
November 20, 2024 at 1:33 PM
Scroll down with arrow to last notification,and subsequently press back button.
Didn't work.Still have list with red dot that says mark all notifications as read.When I press back arrow it returns to tv.
You have to go into mol3 menu>list of notifications,scroll list of notifications with a red dot in front off and scroll down,when all notifications with red dot are covered,press back button,all these more recent notifications are deleted,when you press back button you will indeed go to live tv,however if you check again in mol3 menu,you will see that all recent notifications are deleted!
How do you mark them with the red dot.My dot is on the lower right corner and I can't get to it,thanks
You misunderstood me ,most recent notifications are already marked by a red dot in front of it.
E.g. notification 1, is recording started,notification 2 is recording ended,notification 3 is new content has arrived etc.
Each notification will be marked by a red dot in front of it,just ignore the red dot in the lower right corner,in order to delete these "marked" notifications,just do as i described in earlier post
None of the notifications are marked with a red dot.
You can not delete them, only mark with red button as read!
Hopefully they will remove it from mytvonline3.
After a "refresh" its fine to get a popup which shows refreshed or so.
How do I mark them.I've tried everything
If you go to notifications and scroll down, the red button normally disappears. You cannot delete all notifications. This happens automatically once you have read them, I think!
Why doesn't audio work when trying to watch a previously aired series episode?
Did you install audio optimizer
No.Where do I find it? Thanks
Hello my friend,
In the market app. (Green logo)
And "audio optimizer" app a has black logo What you find in the Market app.
After download open it and run once please
Thanks,Audio Optimizer fixed it.New Question:I successfully record a show then I get a notification that says " Recording has failed".
How do I put aTV series into History for later viewing?
Mark it as Favorite.
How do you delete Search History
Press green button,press back button,navigate to delete token,press back button again.
Good job. If you watch first a tv channel for first time woth folby audio, you get popup message with audio codec. Install it, when you push cancel the popup wont coming back again. Thats why they invent audio optimizer.
I'm lost. Please explain.Why do I get "Recording Failed" notification when the show is recorded.
Is the usb stick formatted with Rufus on windows with ntfs file system?
I'm going to install new usb stick on windows 10.Shoud I use ntfs or fat23 file system? formuler shows the usb that I'm using hasn't been formatted.Maybe that's the problem.
Yes,you should format on laptop or desktop pc to nfts using Rufus tool,non-formatting is for sure a problem!
Yes m, on windows with rufus tool formatting to NTFS with 64kb clustersize.
Used Rufus to format SanDisk but the only option is LargeFat32,NTFS was not a choice,set clustersize to 64kd.Formuler still doesn't recognize disk
Strange, ntfs should always be a choice.
First format fat32.
Maby then appears ntfs.
If not, format with windows self the sandisk with ntfs and 64kb clustersize.
After that you can try if option appears with rufus. If not. Try on your box while its formatted with windows to ntfs.
and if you have skills... re-partition your sandisk. Delete all partitions. Make 1 partition and foemat as ntfs.
Does your stick have maybe two partitions? If yes, delete both and create only one part. then format with NTFS.
For all problems with any drive from USB stick to SSD I use software from Hddguru
EPG has "No information".How do I get it back?
How are you connected; MAC/XC/m3u?
Please check in EPG tag cloud for more info&solution!
Btw you can not post all your queries in notifications thread
If it was before? Contact your provider first
Figured it out.Just refreshed EPG
