Dear community,
We had a power outage yesterday. Since then, it has no longer been possible to connect my Formuler Box to the Internet. (it shows a connection, but it doesn't work)
Other devices such as the TV or Playstation work perfectly. I have also already replaced the HDMI cable.
What options are there?
(I use a Formuler Z10 pro)
No Internet connection (after a power outage)
- Help
- Z10 Pro
Ramonyt -
December 10, 2024 at 7:23 PM
Have you tried to reboot both Formuler and router?
Is there a question mark or an exlamation mark on internet connection given?
Are you on ethernet or wifi connection?
Yes, both for several times
I tried ethernet and wifi. It shows that im connected with my home-wifi.
yes, there is an exlamation mark on internet connection -
Then go on Ethernet/Wifi and hit again on DHCP so you can get new Ip from router, restart the box later again.
yes, there is an exlamation mark on internet connectionDid you fixed it?
Did you do what sam said?
