What is the maximum internet speed on the Z10 Pro Max 100 or 1000M? I had 1000 when I bought it but today I only have 100. What's going on?![]()
100 or 1000M (gigabit)?
- Hardware
- Z10 Pro Max
Mikkeller -
December 17, 2024 at 6:03 PM
1GB for Max pro.
What's going on?
Check your Router and restart Router and Box.
The box is factory reset and updated. I don't have a router, but the internet comes from a fiber optic splitter. I have 250Mb up and down.
Still only 100 Mbts -
Still only 100 MbtsThe ethernet port your Pro Max is connected to or the Ethernet cable your are using only supports 100M.
Thanks for the answer.
If I plug the same ethernet cable into the Apple TV, the speed program shows 250M. -
Please open the "System Info" widget on the home screen and verify the model name.
Please try a different Ethernet cable and report back.
It was the cable. Thanks for your time and help!
