Apps won't connect anymore
  • I don't understand. At all. From one day to the next, no other apps work on the box that I sideload. Downloader doesn't work. Apps I had before now don't work. Has anyone had this? I'm trying to download tivimate with Downloader and Donwloader thinks I'm not connected though I am.
    So frustrating.
    So frustrating.
    If it worked yesterday and today Not anymore, then it looks like google something changed in google play or so.
    Downloader i heard already that it didnt work anymore on z8.
    But from one day to next day and more apps wont work anymore...
    Must be google.
    You can try a factory reset and start fresh. Dont use google play. Only sideload apps then.
    But remember... google can update his system apps without google account. So if its updates, it can block automatic some apps which arent secured anymore.
  • I have a portal setup that has worked great for months. The portal is with **** In the last few days my favorite channels in formuler will open AccuWeather. They used to open Sky Sports, BBC, BT SPORT, etc. The menu on formuler still says the name of the channel I want . However, all point and open AccuWeather in the USA
    How to get help here is the question.
    Contact your iptv provider then my friend.
    They supply the channels.
  • Well on their app everything match's perfect. It's the channel addresses in Formuler that doesn't. I use formuler because of the ability to record and time shift. If all I can get is weather why spend $160 for a ott box, when a $40 box will work.
    Let me clear...
    If you start your box and start mytvonline2...
    ...you go to favorites where your favorite channels are ofcourse and when you select a channel (as example sky sport) you get a AccuWeather channel??
    If yes...?
    Shutdown mytvonline2, clear cache mytvonline2, hold on/off button on remote for 2 seconds and restart/reboot box!
    Can it be you have the box in standby modus?
    if yes... please do every day from the mytvonline2 menu push the "refresh" button.
  • By the way, to go back to the topic of the post which I first opened.
    I got a Z11 Pro Max. None of this is happening anymore. So. clearly either the apps being updated made them incompatible with the Z Alpha's Android version or the box itself stopped allowing new apps to be installed and used.
