I've tried a mol2 z10 box and it has a buffer setting labeled "disabled", which works fine.
Can we have the same in mol3?
Only short or long options are not enough
What for? Disabled Buffer means you don`t have any stream buffered in advance and each small interrupt in network can lead into circle buffering or freeze. Second the option Skip Ahead would also not work. Short is good selection if network works fine and long if often buffers or freezes.
I already have circle bufferings, and if it was useful on mol2 why isn't it on mol3?
If not useful at all why not removing it on mol2?
Something is illogical
Formuler could do better to have more than 1 adjustment for buffering needs - HINT HINT! As another possible test to see if it's on the services end of the supply line or your end without having enough internet data speed you could download the OTT navigator app, install your service & raise the buffering time on it. That app does have far better adjustability for buffering time than the MyTvOnline3 app does. This would confirm if you indeed do need more buffering than the LONG selection of the MyTvOnline3 app can provide, or if it's really a supply from the service problem. One thing I have learned & have been able to diagnose is many services can't provide enough upload speeds for the amount of consumers pulling from it. I notice this problem mainly on sports, football and the like. Using a different app to access or grabbing from your local off air is an alternative if this is the case. I have done this many times when this problem rears it's ugly head!
