The TV3 app starts up for 2 seconds than shuts of ( back to start screen )
  • Beste allen,
    Kan iemand mij een tip geven hoe ik de Tv online app herstel, kan 2 seconden kijken en dan stopt deze automatisch. heb het kastje nu 3 maanden.
    Dear,
    Is there annyone who can help me with the issue of my TV3 app shutting down after 2 seconds.... have no clou.
  • Hi,try uninstall mol3 app and reinstall from Formuler Market.
    For further info read thread"MyTv Online3shutd off automatically",esp.post11 by Z3zinho
    Edited once, last by henkie (December 25, 2024 at 2:44 PM).
  • Make sure that when you power off the box when you’re finished using it you don’t put it in standby and then full power off.
    If you do that, when you power back on, the box will boot but will return to last state which will be standby.
    If you’ve ruled out the above being the issue. Clear cache and data and as Henkie suggested, uninstall and reinstall the app.
    Still if the problem persists, hard restet and start from scratch would be the easiest solution.
  • Beste allen,
    Dear,
    Please access Home screen > Settings > Apps > MYTVOnline 3 to clear the cache and check again.
    Let me know your results.
